Mart-in
Tabulate
I can't achieve to tabulate some variables in order to make descriptives statistics.
Would you see my file.
I would describe the "Type d'intervention" in function the "Groupe de randomisation" with percentage of total and in function of the "Age".
I will be so greateful for your help.
Sincerely,
Byron_JMP
Re: Tabulate
Sometimes just asking the question helps to find the solution. If you wouldn't mind, could you post a comment on the error you found and what it caused?
Mart-in
Re: Tabulate
I have succeeded, there was an mistake on the excel data.
Sincerely,
Byron_JMP
Re: Tabulate
