gwhitcomb
Tabulate in script not creating table seen in control panel
I am trying to tabulate a table and use a filter simultaneously to create a table that pulls out 6 rows of data that I can then join to another data table. The table that I see in my control panel is correct but when the script runs and creates the data table I am getting different data. Below is the code I use and 2 screen shots. Why is the table created different than the table seen in the control panel?
(Data Table("SILZone")<<Tabulate(
     Add Table(
          Column Table(
                          Analysis Columns( :Name( "Sum(BOTTLESOUT)" ) ),
            Statistics( Mean, Sum )
            Row Table( Grouping Columns(:DATE, :SHOP, :LOOP ) )
      Local Data Filter(
            Location( {208, 121} ),
            Add Filter(
                  columns( :ZONENAME, :LOOP ),
                  Where( :ZONENAME == "Gob Cuts" ),
                  Where( :LOOP == 0 ),
                  Display( :ZONENAME, Size( 284, 259 ), List Display )
            Mode( Select( 0 ), Show( 1 ), Include( 1 ) )
<< Make Into Data Table;
=current data table();
<<set name("GobCuts");
From the tabulate control panel. This is the table I want:
This is what I get when I run the script:
pmroz
Re: Tabulate in script not creating table seen in control panel
Try using get rows instead of a local data filter.  Here's some code:
dt = Data Table("SILZone");
current data table(dt);
selected_mtx = dt << get rows where(:ZONENAME == "Gob Cuts" & :LOOP == 0 );
if (nrows(selected_mtx) > 0,
    dt << select rows(selected_mtx) << invert row selection << exclude << clear select;
    dt_tab = dt << Tabulate(
        Add Table(
            Column Table( Analysis Columns( :Name( "Sum(BOTTLESOUT)" ) ),
        ), invisible
    dt2 = dt_tab << Make Into Data Table;
    dt_tab << close window;
    dt2 << set name("GobCuts");
    dt << clear row states;
pmroz
        Add Table(
        ), invisible
gwhitcomb
Thank you! That works perfectly. I had been playing around with get rows and couldn't get it to work. I appreciate your help!
