MuttonChops
Tabulate a variable column list
I am using the following to generate a column list, which varies but always has an "X_Clean" in the name:
col_list = dt<<get column names(string);
	for(i=nitems(col_list), i>0, i--,
		if(!contains(col_list[i], "X_Clean"),
				remove from(col_list, i);
Now I'm trying to create a tabulate box but I'm unsure how to reference this col_list in the Analysis Columns.
dtLUB= vlistbox(dt<< Tabulate(
	Change Item Label( Statistics( Max, " " ) ),
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Analysis Columns( :Date ), Statistics( Max ) ),
		Column Table(
			Analysis Columns(
Need to insert col_list here somehow
			Statistics( Max )
		Row Table( Grouping Columns( :Entity) )
		Dispatch(
			"Tabulate",
			OutlineBox,
			{Set Title( "PM Counter Summary as of: "|| TimeStamp )}
Re: Tabulate a variable column list
This should work
	Add Table(
		Column Table(
			Analysis Columns(
				eval( col_list )
			Statistics( Max )
		Dispatch(
			"Tabulate",
			OutlineBox,
This should work
	Add Table(
		Column Table(
			Analysis Columns(
				eval( col_list )
			Statistics( Max )
		Dispatch(
			"Tabulate",
			OutlineBox,
MuttonChops
Thanks Jim!
