hogi
Level XIII
Tabulate - N categories ?
Tabulate and Tables/Summary are very similar, but ...
hey, Tabulate, what is the difference between counting numerical and non-numerical categories?
dt << Summary(
	Group( :age ),
	N Categories( :sex )
dt << Tabulate(
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Analysis Columns( :sex ), Statistics( N Categories ) ),
		Row Table( Grouping Columns( :age ) )
Tables/Summary:
Tabulate:
same settings, but Tabulate will fail and generate a warning:
hogi
Level XIII
Re: Tabulate - N categories ?
dirty workaround:
Tabulate(
	Transform Column(
		"sex_num",
		Formula( Col Rank( :sex, <<tie( minimum ) ) )
	Add Table(
		Column Table( Statistics( N Categories ), Analysis Columns( :sex_num ) ),
hogi
Level XIII
dirty workaround:
Tabulate(
	Transform Column(
		"sex_num",
	Add Table(
hogi
Level XIII
fun fact:
for header statistics, N unique (= N categories)  is available for categorical entries:
... but not for continuous ones:
Steffen_Bugge
Good point @hogi ! Why don't the N categories work in the Tabulate platform? Do you know if it exist a Wish List item to get this implemented?
hogi
Level XIII
According to my records, there is no entry in the wish list.
happy news:
With JMP19, it's now MUCH easier to use the workaround with the dense rank:
 Col Score()
New in Graph Builder for JMP 19
Tabulate(
	Transform Column( "Score Unique[sex]", Formula( Col Score( :sex ) ) ),
	Add Table(
		Column Table( Statistics( N Categories ), Analysis Columns( :sex) ),
		Column Table( Statistics( N Categories ), Analysis Columns( :"Score Unique[sex]"n ) ),
