‘New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit – register now, free of charge.
Level XI
Tabulate - N categories ?
Tabulate and Tables/Summary are very similar, but ...
hey, Tabulate, what is the difference between counting numerical and non-numerical categories?
dt << Summary(
	Group( :age ),
	N Categories( :sex )
dt << Tabulate(
	Add Table(
		Column Table( Analysis Columns( :sex ), Statistics( N Categories ) ),
		Row Table( Grouping Columns( :age ) )
Tables/Summary:
Tabulate:
same settings, but Tabulate will fail and generate a warning:
Level XI
Re: Tabulate - N categories ?
dirty workaround:
Tabulate(
	Transform Column(
		"sex_num",
		Formula( Col Rank( :sex, <<tie( minimum ) ) )
	Add Table(
		Column Table( Statistics( N Categories ), Analysis Columns( :sex_num ) ),
Level XI
dirty workaround:
Tabulate(
	Transform Column(
		"sex_num",
	Add Table(
Level XI
fun fact:
for header statistics, N unique (= N categories)  is available for categorical entries:
... but not for continuous ones:
