Register for May 2 Mastering JMP Demo - Circumventing Common Pitfalls in Predictive Modeling
Remove Duplicates
hcarr01
How to remove duplicates (same values) in the same column?
This post originally written in French and has been translated for your convenience. When you reply, it will also be translated back to French .
ChristianBille
Re: Supprimer les doublons
An easy ad hoc solution could be to right-click and press select matching cells and then hit delete.
Does that help?
cheers
Christian
hcarr01
Re: Remove duplicates
I am looking to in the same column, remove all duplicates but keep exactly 1 time the value corresponding to all duplicates.
Thanks anyway !
FN
FN
You can do it using the row selection menu.
First, you find and select duplicates (see below).
Then, you simply delete the rows selected (same menu, Rows>Delete Rows)
Be aware that you get different answers depending on the columns you are selecting (if none, JMP looks at all columns).
Victor_G
Hi @hcarr01,
Another option could be to use the platform "Subset" available in the menu "Table".
Here is my example datatable before (with duplicate values):
Then using the platform "Subset", specifying that I want only one value for each levels/unique values of my column (using my selected column as a stratification), you end up with the result you want :
As you can see, there are many ways to do this in JMP
I hope this will help you,
Victor GUILLER
