Stacked table will be very large warning.
Hello everyone,
Sometimes while I run the automated JSL I get the following warning:
"The new stacked table will be very large. ... Do you wish to proceed?"
The annoying part is that it interrupts the scripts, and I have to manually press Continue. Is there a way to suppress this kind of warnings so they do not pop out?
Thank you everyone.
Re: Stacked table will be very large warning.
How are you running your script? For me it will just print it to the log and not interrupt the script execution (using JMP18.0.1 on Windows 10 so might be different on OSX).
dt = As Table(J(10000, 10000));
dt << new column("A", Character, Nominal, Set Each Value("A"));
dt << new column("B", Character, Nominal, Set Each Value("B"));
dt << new column("C", Character, Nominal, Set Each Value("C"));
dt << new column("D", Character, Nominal, Set Each Value("C"));
dt << new column("E", Character, Nominal, Set Each Value("C"));
dt << new column("F", Character, Nominal, Set Each Value("C"));
cols = dt << Get Column Names("Continuous", String);
dt_stacked = dt << Stack(columns(eval(cols)));
You could try Batch Interactive(1) and Batch Interactive(0) commands
Batch interactive(1);
Batch interactive(0);
