Assaf1
Stack with spec limits
How can I perform new table by stack for several columns with spec limits (as properties) and create two new columns with spec low and spec high each Label according to initial table properties?
See attached
If possible, also pass/fail column
Thanks in advance!
Assaf
Re: Stack with spec limits
The best way to learn about this is in the Scripting Guide.  See:
     Help==>Books==>Scripting Guide........Construct a Column Dialog
Here is a simple script that will illustrate one way to do this
dtOrig = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
// Modify the data to make it simpler for the example
dtOrig << delete columns( 10 :: 132 );
dtOrig << delete columns( 1 :: 4 );
dtOrig << select where( Row() > 50 );
dtOrig << delete rows;
// Stack the data
dtStacked = dtOrig << Stack(
	columns( :NPN1, :PNP1, :PNP2, :NPN2, :PNP3 ),
	Source Label Column( "Parameter" ),
	Stacked Data Column( "Value" ),
	Output Table( "Stacked" )
// Create the new columns
dtStacked << New Column( "Lower Spec Limit" );
dtStacked << New Column( "Upper Spec Limit" );
// Move the Spec Limits
colList = dtOrig << get column names( string );
For( i = 1, i <= N Items( colList ), i++,
	specs = Column( dtOrig, colList[i] ) << get property( "spec limits" );
	foundRows = dtStacked << get rows where( dtStacked:Parameter == colList[i] );
	dtStacked:Lower Spec Limit[foundRows] = specs["LSL"];
	dtStacked:Upper Spec Limit[foundRows] = specs["USL"];
Assaf1
Thanks a lot!!
Using your support I performed the follows script:
  • BTW, How can I add popup window to modify the red line?
// Stack the data
// Stack the data
dtOrig = currentdatatable();
columns( 26 :: 42 ),
New Column("P/F", Numeric, "Continuous", Formula((:Lower Spec Limit <= :Value <= :Upper Spec Limit) == 0));
Assaf1
Thanks a lot!
