billi
Level V
Stability platform vs destructive degradation platform
What is difference between stability test platform and destructive degradation platform? Both the platforms will give information about the degradation and time when specified limit will be crossed.
Joseph_Reese
Re: Stability platform vs destructive degradation platform
Stability analysis is primarily used by the pharmaceutical industry to help set product expiration dates. The sample isn't destroyed in that case, it rather crosses some threshold where the product is no longer considered acceptable. The help documentation walks through a nice example and gives some additional background.
peng_liu
Stability within Degradation platform is an application of repeated measures degradation analysis. It is also a very specialized application, which tries to be compliant with a guideline in the pharmaceutical industry. It is not intended to be used out of the context.
