Stability Analysis Course Error Message
I am trying to do the Stability Analysis Training course but I get this error message when I try to generate the very first stability data:
Any idea what the issue is? This is from the training notebook provided by JMP. I'm using JMP 18.0.1
Thanks,
Carmen
Re: Stability Analysis Course Error Message
This error typically occurs if you did not click the Initial Setup link at the top of the journal. I could only reproduce your error by clicking on the first data table WITHOUT clicking on Initial Setup.
Dan Obermiller
Dan Obermiller
Thanks! That was the mistake i made.
