chandankishor66
Split the information from one column and put them into several columns
Hello JMP Users,
I need your help to split the infomation from Column 1 and put them into several columns.
Regards,
Chandan
Phil_Kay
Re: Split the information from one column and put them into several columns
You can do this kind of thing with column formulae. However, I find it best to use the Recode platform. I suggest that you look at the help documentation. In particular Advanced > Extract Segment.
I hope that helps,
Phil
chandankishor66
Thanks Phil, Your suggestion worked for me.
