AsymptoticCos
Split a Table without a Split by Column
I have a data table that looks like this,
I want to change it to something like this.
How do I do this in JSL? I don't have a reference column to split this against, but I know odd rows will be my first entry, and even rows will be my second entry always.
Re: Split a Table without a Split by Column
Create new column with the knowledge you have about odd and even rows and use that as your Split By column
dt = New Table("Untitled 2",
	Add Rows(8),
	Compress File When Saved(1),
	New Column("Column 1",
		Character,
		"Nominal",
		Set Values(
			{"Test1", "Test1", "Test1", "Test1", "Test1", "Test1", "Test1", "Test1"}
	New Column("Column 2",
		Character,
		"Nominal",
		Set Values(
	New Column("Column 3",
		Character,
		"Nominal",
		Set Values({"A", "1", "B", "2", "C", "3", "D", "4"})
dt << New Column("By", Character, Nominal, Formula(
	If(Mod(Row(), 2),
		"Data 1";
		"Data 2";
dt_split = dt << Split(
	Split By(:By),
	Split(:Column 3),
	Output Table("Untitled 29.jmp"),
	Sort by Column Property
	Add Rows(8),
		Character,
		"Nominal",
		Set Values(
		Character,
		"Nominal",
		Set Values(
		Character,
		"Nominal",
	If(Mod(Row(), 2),
		"Data 1";
		"Data 2";
	Split By(:By),
	Split(:Column 3),
