What you want can be accomplished using the
Tables=>Split
Below is a simple script taking the JSL provided from the Split Platform, and then just adding on the JSL taken from the Recode feature
// Get the column names that will need to recoded to 0 if missing
Summarize( dt, colnames = by( :Order Number ) );
// Do the simple split to transform the data table
dtSplit = dt << Split(
Split By( :Order Number ),
Split( :Quantity ),
Group( :Item, :Part Number ),
Sort by Column Property
// Loop across all split columns and recode missing values to zeros
For( i = 1, i <= N Items( colnames ), i++,
dtSplit << Begin Data Update;
dtSplit << Recode Column(
As Column( dtSplit, colnames[i] ),
{Map Value( _rcOrig, {., 0}, Unmatched( _rcNow ) )},
Update Properties( 1 ),
Target Column( As Column( dtSplit, colnames[i] ) )
dt << End Data Update;
