trevorphysics
Split Data Table Issue
I am having some difficulty splitting tables and keeping the data grouped together correctly. Here is sample data:
V1I1Test CountSweep Name
001Forward
0.10.11Forward
0.20.21Forward
0.30.31Forward
0.40.41Forward
0.50.51Forward
0.60.61Forward
0.70.71Forward
0.80.81Forward
0.90.91Forward
111Forward
1.11.11Forward
1.21.21Forward
002Forward
0.10.12Forward
0.20.22Forward
0.30.32Forward
0.40.42Forward
0.50.52Forward
0.60.62Forward
0.70.72Forward
0.80.82Forward
0.90.92Forward
112Forward
1.11.12Forward
1.21.22Forward
001Reverse
0.1-0.11Reverse
0.2-0.21Reverse
0.3-0.31Reverse
0.4-0.41Reverse
0.5-0.51Reverse
002Reverse
0.1-0.12Reverse
0.2-0.22Reverse
0.3-0.32Reverse
0.4-0.42Reverse
0.5-0.52Reverse
0.6-0.62Reverse
0.7-0.72Reverse
0.8-0.82Reverse
When I split the table...
dt << Split(
	Split By( :Sweep Name ),
	Split( :V1, :I1 ),
	Output Table( "Split Table" ),
	Sort by Column Property
I get the following table:
Test CountV1 ForwardV1 ReverseI1 ForwardI1 Reverse
10000
10.10.10.1-0.1
10.20.20.2-0.2
10.30.30.3-0.3
10.40.40.4-0.4
10.50.50.5-0.5
10.600.60
10.70.10.7-0.1
10.80.20.8-0.2
10.90.30.9-0.3
110.41-0.4
11.10.51.1-0.5
11.20.61.2-0.6
200.70-0.7
20.10.80.1-0.8
20.2 0.2
20.3 0.3
20.4 0.4
20.5 0.5
20.6 0.6
20.7 0.7
20.8 0.8
20.9 0.9
21 1
21.1 1.1
21.2 1.2
JMP ends up aligning test count incorrectly for all the reverse data because the number of data points is not necessarily equal between any test.
What I want is the following:
10000
10.10.10.1-0.1
10.20.20.2-0.2
10.30.30.3-0.3
10.40.40.4-0.4
10.50.50.5-0.5
10.6 0.6
10.7 0.7
10.8 0.8
10.9 0.9
11 1
11.1 1.1
11.2 1.2
20000
20.10.10.1-0.1
20.20.20.2-0.2
20.30.30.3-0.3
20.40.40.4-0.4
20.50.50.5-0.5
20.60.60.6-0.6
20.70.70.7-0.7
20.80.80.8-0.8
20.9 0.9
21 1
21.1 1.1
21.2 1.2
I have played around with the group option with split data table but it always seems to drop off data. For example, if I group by test count, it only gives me a single row per test count and seems to pick whatever the last value is in that test count for forward and reverse.
Hopefully this all makes sense. Thanks in advance for the assistance.
frank_wang
Re: Split Data Table Issue
Hi
My solution include two steps. Transpose then Split.
Before table change, I create a new col named "Tag" with formula
Current Data Table() << New Column( "Tag",
formula( Col Rank( :Test Count, :Test Count, :Sweep Name ) )
Transpose data table
Current Data Table() << Transpose(
	columns( :V1, :I1 ),
	By( :Test Count, :Tag ),
	Label( :Sweep Name ),
	Output Table( "Transpose of Untitled" )
Then split as last step
Data Table( "Transpose of Untitled" ) << Split(
	Split By( :Label ),
	Split( :Forward, :Reverse ),
Final table like this
Have a good day!
心若止水
frank_wang
Hi
	Split By( :Label ),
Have a good day!
心若止水
trevorphysics
View more...
That's very clever and works perfectly. Thank you!
