AT
AT
Level V
Spec limits issue
I am trying to import spec limits and having some error when I ran the script. Here is the script and error:
dt = Current Data Table();
Eval(
Parse(
   "obj = dt << Process Capability(
Process Variables( "|| names ||
Spec Limits(Import Spec Limits("SpecA.jmp") )   )  ;"
 The names varaible has all columns and worked fine in other script. I appreciate any help.
AT
AT
Level V
Re: Spec limits issue
Thanks Jim. I made it to work.
16 REPLIES 16
David_Burnham
I've only given the script a quick glance, but one problem I see is that you have quotes contained within your quoted string.  Specifically the name of the table is in quotes, and those quotes are part of a larger quoted string.  To embed quotes within a string you need to use the escape sequence \!" ... so where you have Import Spec Limits("SpecA.jmp") you need Import Spec Limits(\!"SpecA.jmp\")
-Dave
There is an Addin that populates limits into a data table, from another JMP limits table.  See
Write Limits to a Data Table from a Limits Table
cwillden
Aside from using "\[ ]\" to mask double quotes in a string, I also find that the Eval Insert() function is very handy for including the values of variables in a string, like the variable "names".  You can insert the values of variables into a string using the carrot symbol "^".  Here's how you might be able to get this to work:
Eval(
	Parse(
		Eval Insert("\[obj = dt << Process Capability(
			Process Variables(  ^names^ ),
			Spec Limits(Import Spec Limits( "$DESKTOP/SpecA.jmp") ) );]\"
Of course, your SpecA.jmp may not be on your desktop.  Just make sure the path is correct for that file.
-- Cameron Willden
AT
AT
Level V
Thanks for all your suggestions. I am still getting an error with the last suggestion.
Exception in platform launch in access or evaluation of 'Process Capability' , Process Capability(/*###*/Process Variables(
:A,B,...
Any further help is appreciated. Thanks
cwillden
Can you post the value of the variable "names"?  It may not like the format for your list of column names.
-- Cameron Willden
AT
AT
Level V
Thanks for the reply and feedback. Here is what the definition of "names" is
lstNames = dt << Get Column Names( string, Numeric );
  names = ":" || lstNames[1];
  For( i = 2, i <= N Items( lstNames ), i++,
names = names || ",:" || lstNames[i]
I have used "names" in other part of JMP script and no issue. Thanks
AT
AT
Level V
I found out that in my list of columns for some reason A_B is written as A-B and fixing this will work with the following script.
Eval(
Parse(
Eval (
"obj = dt << Capability(
Y(" || names || "),
Spec Limits(Import Spec Limits(\!"SpecA.jmp\!") ) );"
Thank you all for great support. Best
AT
AT
Level V
How do I  import Spec Limit without doing any capability analysis in a script ?
Thanks
My suggestion is that you import the spec limits as column propery, independent from the Distribution Platform.  then when you run the platform, you specify,
Distribution(
     Continuous Distribution( Column( :NPN1 ),
     Capability Analysis( 0 ) )
Examples of all elements availabe to any of the platforms is available in the scripting index
     Help==>Scripting Index
I suggest you familiarize yourself with it.  It is the answer to most of your questions.
An example:
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
USL = 70;
LSL = 55;
Eval(
	Substitute(
			Expr(
				:Height << set property( "spec limits", {LSL( __LSL__ ), USL( __USL__ ),Show Limits(1)} )
		Expr( __LSL__ ), LSL,
		Expr( __USL__ ), USL
Distribution( Continuous Distribution( Column( :height ), Capability Analysis( 0 ) ) );
