kar456
Sorting Tabulate by Statistic
I have I am trying to be able to create a tabular table where I can sort the values by the statistic, such as mean value. So for example, for the sample file "Car Poll",  I have the following basic tabulate code:
Tabulate(
       Add Table(
       Column Table( Analysis Columns( :age ), Statistics( Mean ) ),
       Row Table( Grouping Columns( :size ) )
Which produces the following pivot table:
                 Age
size         Mean
Large        33.3
Medium    30.7
Small       30.0
but I would like to be able to sort the means in descending value so the first row shows "Medium " and it's values, 2nd row as "Large", and 3rd row as "Small". I know there is a
Sort(By()) function for data tables, but there doesn't seem to be anything similar for tabulate. Does anyone have a suggestion of how I could achieve this?
Thanks!
ms
Super User (Alumni) ms
Re: Sorting Tabulate by Statistic
I can't find a direct interactive way to sort a tabulate report. However, it acknowledges the value ordering column property.
This code should work to conditionally set value ordering for a column (only tried it in JMP 10):
dt = Open( "$SAMPLE_DATA/Car Poll.jmp" );
col_list = {:size, :age};
Summarize( g = by( col_list[1] ), m = Mean( col_list[2] ) );
col_list[1] << Set Property( "Value Ordering", Eval( g[Rank Index( m )] ) );
dt << Tabulate(
  Add Table(
  Column Table( Analysis Columns( col_list[2] ), Statistics( Mean ) ),
  Row Table( Grouping Columns( col_list[1] ) )
ms
dt << Tabulate(
  Add Table(
