JSL Cookbook - Archived
Building blocks of JSL code to reduce your coding workload.
Sort a Data Table
Problem
You need to sort a table using one or more columns as the sort key.
Solution
Use the table's sort method, which supports ascending and descending order and in-place or new table sorting.
// run these lines, one at a time, to see the effects
// (place the cursor on the line and use the Enter key
// on the numeric keypad to easily submit the line.)
dt = Open( "$sample_data/big class.jmp" );
// example 1: makes a new table
new table = dt << sort( by( height, weight ) );
Wait( 2 );
Close( new table, nosave );
// example 2: updates table in place
dt << sort( by( height, weight ), order( descending ), replace table );
Wait( 2 );
Close( dt, nosave );
// example 3: keep a column of original row order
orig = dt << New Column( "original row", formula( Row() ) );
dt << runFormulas; // make sure the background formula evaluation is done, then
orig << deleteFormula; // delete the formula so it won't run after the sort (!)
Wait( 2 );
dt << sort( by( orig ), order( ascending ), replace table );
Wait( 2 );
Discussion
The final example shows adding a new column to capture the original sort order and how to use that new column to resore the original order. The documentation shows another useful option to name the table.
new table = dt << sort( by( height, weight ), Output Table Name("Fred") );
See Also
Documentation
Comments
i think the statement
be more efficient as
 dt << New Column( "original row", set values( 1::(N Rows(dt)) );
Thanks for the example!
Good point. Rather than evaluate a formula for each row, then remove the formula, just build the sequence as a matrix (the :: operator) and initialize the column directly. Thanks!
JSL Cookbook
If you’re looking for a code snippet or design pattern that performs a common task for your JSL project, the JSL Cookbook is for you.
This knowledge base contains building blocks of JSL code that you can use to reduce the amount of coding you have to do yourself.
It's also a great place to learn from the experts how to use JSL in new ways, with best practices.
