robot
Solve y = f(y,x)
I would like to use JMP to solve for y in an equation of the form y = f(y,x).  A more precise equation is attached.  This problem seem similar to that discussed in Numerical solver add-in, although a clear solution is not mentioned.
In the attached equation, y is response, x is predictor, and a - k are fitting parameters.
What is the best way for JMP to tackle this?  I am using JMP11.  Thanks!
Hegedus
Re: Solve y = f(y,x)
I will make an assumptions: You have a series of data points with both x and y measured.
The way I have handled this in the past since you have an implicit equation, is to recast it as an explicit equation by creating a new function.
If you subtract the left hand elements from both sides you get an equation equal to zero.
0 = right hand(x,y) -  left hand(x,y)
Now substitute a variable for zero so you have a new equation.
z = right hand(x,y) - left hand(x,y)
Now set Z at all points equal to 0 (zero) and solve as a multi-variable problem.
Caveat I have not done a rigorous error analysis on this technique, but just used in the past with success.
Good Luck.
Andy
Hegedus
Good Luck.
Andy
robot
Thanks Hegedus, that works!
