Sysy13
Sixth data extraction
Let say I have data "12345278" and "12345078" and would like to extract out the sixth, any formula I can use?
Coz if use Right(data,3), then the data will be "278" or "078"
For every sequence have to be extracted out in diff column, so it might be quite inconvenient to use like this: Left(Right(data,3),1)
Any suggested method to do this?
Craige_Hales
Re: Sixth data extraction
The Scripting Index is in the Help menu.The Scripting Index is in the Help menu.
Craige
Craige_Hales
Craige
Sysy13
Thank you!
