Is it by design that header summary graphs aren't affected by column properties such as Missing Value Codes and Value Labels?
Created:
Feb 14, 2023 05:43 AM
| Last Modified: Jun 8, 2023 9:36 AM(3342 views)
Is this by design that Column properties don't seem to affect header summary graphs?
Here I have set Missing Value Code to "M" and Value Label to F = "Female" and you can see difference between the header summary graphs and distribution plot:
the issue with the value labels got fixed. (Jmp 17.2)
concerning Missing Value Code and non-continuous columns - hm, Distribution seems to be the outlier. Will it be fixed to be consistent with the other plots?
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '600800' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '600800') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '600800') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
