CNU
CNU
Simulations
Hi
How do I create a simulation with a relative standard deviation for the input factors?
Re: Simulations
You can't, if I understand your question. You are definition sampling distributions for the input variables or factors. The standard deviation is in terms of the variable, using the same units. You can convert a relative measure, such as % CV, by multiplying the RSD by the mean.
I might have completely misunderstood your question.
CNU
CNU
Re: Simulations
What I want to do is to estimate the defect rate where one of the input variables is the mass with a relative standard deviation of +/- 2%. The input range for the mass is 20-100 kg.
Re: Simulations
This simulator assumes that each factor has a constant set point but the actual setting varies from run to run. You provided a factor range of 20 to 100 kg. What is the desired or optimal set point weight?
The RSD is a constant, so the SD is not a constant. You can use a JSL expression to define the distribution of input factor values instead of selecting one of the distribution models with a constant mean and SD.
CNU
CNU
Re: Simulations
Can you help with this JSL expression? How do I define SD from the actual setting and RSD?
Re: Simulations
We are going in circles. The Profiler uses a fixed factor set point (e.g., W/T = 0.55 above ). It uses this value as the location of the chosen distribution, and it does not change during the simulation. It uses the spread (e.g., W/T SD = 0.03 above) to generate random deviates based on a selected distribution (e.g., normal distribution). If you have a RSD, say 5%, then the absolute SD is RSD * Location = 0.05 * 0.55 = 0.0275.
The choice of Expression allows you to use any valid JSL expression that returns a number. For example:
Random Normal( 50, 5 );
Will generate normally distributed deviates from a normal population with a location of 50 and a spread of 5. You could replace either the constant location or the constant spread or both with another expression that varies the value deterministically or randomly. I do not know how you would use this ability because you still have not answered my previous questions.
See the documentation for the Profiler Simulator factor settings.
CNU
CNU
Re: Simulations
Sorry for not being clear on this.
If I use a fixed set point of W/T = 0.55 and then apply the expression as shown:
Then SD is 0.55*0.05 = 0.0275.
Now, I want to simulate the defect rate applying the sequence location in the range from 0.2 to 0.6. When using the expression will JMP use a constant SD of 0.0275 for each the different locations or will the expression be interpreted as location*0.05?
Re: Simulations
I do not see a way to make the SD depend on the location with the JMP controls, even with an expression. There is no variable to access the current location or a way to specify a variable SD. You can sequence location or spread, but not both.
You can manually create a table of 25 combinations of W/T, C, and the associated SD, and then manually set the factor location and SD for each run. This approach could also be scripted as the Profiler and Simulator are fully scriptable.
