Stokes
Simplify JSL in transpose column #
Hi I am trying to reduce the transpose JSL columns.
Currently, when transpose col from col (3) to col (8), each col needs to be listed specifically.
Can I convert it to transpose between col (3) and col (8)? without list each column name.
Thanks
dt = Current Data Table();
dt << Transpose(
	columns(
		Column( 3 ),
		Column( 4 ),
		Column( 5 ),
		Column( 6 ),
		Column( 7 ),
		Column( 8 )
Re: Simplify JSL in transpose column #
Here is one way to do what you want
colNames = (dt << get column names(string))[3::8];
dt << Transpose(
	columns(
		colNames
ErraticAttack
You can index the columns by number:
dt = Open( "$SAMPLE_DATA/Blood Pressure.jmp" );
dt << Transpose( Columns( 2::6 ), By( :Dose ), Label( :Subject ) );
Jordan
dt << Transpose(
	columns(
		colNames
ErraticAttack
Jordan
Stokes
Hi, Both solution works great
