bhpan
Similar function same as excel
Need help on similar function for grouping date/time on new column same as excel <FLOOR(S2,"3:00")>
Re: Similar function same as excel
Here is one way to handle it, assuming that the S2 value is in a column called Column 1 in the JMP Data table
Informat( Short Date( :Column 1 ), "mm/dd/yyyy" )
Here is another
Date MDY( Month( :Column 1 ), Day( :Column 1 ), Year( :Column 1 ) )
Mauro_Gerber
I assume you mean round to the date so you can tabulate over it.
formula: :Column1- Time Of Day( :Column1 )
or: right click on the column header --> New Formula Column --> Date Time --> Date will do the same
"I thought about our dilemma, and I came up with a solution that I honestly think works out best for one of both of us"
- GLaDOS
Georg
I think you want to floor the time to the same value for each 3 hour range.
This works  by
Floor( :date / (3 * 60 * 60) ) * (3 * 60 * 60)
assuming :date is the original column.
First the original date is divided so that 1 is a step of 3 hours (3 hours x 60 min x 60 s, JMP calculates in seconds), than floor is applied, than it is calculated back to the original range.
Georg
This choice is perhaps a matter of personal preference, but JMP provides many functions for date and time values, which can present difficult boundary conditions. (For example, think leap years. Not to worry in this case, but a general caution.) So this case might use this function:
Floor( :date / In Hours( 3 ) ) * In Hours( 3 ) )
