rleeper
Show Scientific notation with Char function?
I have a column that has numbers in scientific notation, I need to annotate a chart title with the values in scientific notation.
To annotate a chart with a number you have to use the Char() function, when I use the Char() function the result is in decimals.
Example:
Dispatch( {}, "graph title", TextEditBox, {Set Text( "Id vs Vg by display. Id range : " || Char(IR))} )
Is there anyway to get the Char function to show the Scientific notation instead?
I tried using a new column that was Character based and referenced the values from the numeric column, and JMP promptly turned the new column into a numeric column.
I tried using a new column that was Character based and used the Char() function in the formula, and the scientific notation automatically got converted to decimal.
ms
Super User (Alumni) ms
Re: Show Scientific notation with Char function?
x = 5e-10;
y = Char(Format(x, "Scientific"));
Show(x, y);
x = 0.0000000005;
y = "5e-10";
ms
x = 5e-10;
Show(x, y);
x = 0.0000000005;
y = "5e-10";
rleeper
Thank you, worked perfectly!
