Wantj43
Shape and dbf files
All the files in the maps folder are formatted “pdf”. If a shape or dbf is saved as a .jmp it is converted to a pdf. Please help!
Thierry_S
Re: Shape and dbf files
Is it possible that you linked the jmp and dbf extension to a PDF reader such as Acrobat?
If it is the case, this article may help:
https://winaero.com/remove-apps-open-with-context-menu-windows-10/#:~:text=Expand%20the%20extension%....
Best,
TS
Thierry R. Sornasse
Wantj43
I am using jmp version 15.1
Here are the map files for JMP 15 that are written during the install.  The default location is:
     C:\Program Files\SAS\JMP\15\Maps
or
     C:\Program Files\SAS\JMPPRO\15\Maps
Here is the listing from that map folder
What folder are you trying to save your map files too?
Are you running Windows 10?
Wantj43
Thank you
Somehow all of the files in the map folder are displayed as PDF and not Jmp files. If a jmp file is placed in the folder by pasting it converts to a PDF.
Thierry_S
Best,
TS
Thierry R. Sornasse
Wantj43
That apparently was the problem.
Thank you very much. I should have posed the problem a week ago.
Thank you again.
Joe
