tom_abramov
Level V
Several charts in Graph Builder with independent axis
I would like to do a "By" action in Graph Builder like in all other platforms.
What I see is only "Page" option but it makes all X Axis the same.
See attached a screenshot.
In this example I would like each chart will have its own categories without categories with no data.
Please help.
Thank you.
Re: Several charts in Graph Builder with independent axis
All you have to do is to add the By clause into the JSL code
dt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
Graph Builder(
	Variables( X( :PNP1 ), Y( :NPN1 ) ),
	Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) ),
	by( :site )
Hi Tom,
When you first open graph builder, there should be a button called Dialog. Use this button to get a dialog interface to Graph Builder which will have the By option you are looking for.
Chris Kirchberg
Chris Kirchberg, M.S.2
www.jmp.com
Graph Builder(
	by( :site )
Hi Tom,
Chris Kirchberg
www.jmp.com
tom_abramov
Level V
Thank you!
