Jim_G_Pappas
Setting path to R location
Hello
I would like to be able to run a couple of R-scripts I have.  Additionally, I'd like to run some of the JMP add-ins that utilize R (ex. Chernoff Faces).   Is there a way to set the pate within preferences or tell JMP where the location of R is on my laptop.   Its not under program files (due to admin rights), as I'm assumming that's where it might be looking.  It is definately on my laptop however, with all pertinent libraries loaded.
To be more specific,  I get the following when trying to run the command R connect();
An installation of R cannot be found on this system. JMP R support requires R version 2.9.1 or higher in access or evaluation of 'Glue' , Names Default To Here( 1 ); /*###*/If( Is Empty( dt = Current Data Table() ),
Any help is appreciated.   Thanks, Jim Pappas
Jim Pappas
Re: Setting path to R location
Look in the Scripting Guide "How JMP Finds R"
     Help==>Books==>Scripting Guide
Jim_G_Pappas
Thanks - that worked great.
Jim Pappas
mrosenthal
What are the adjustments (if available) to do the same process as the book shows with regards to Windows on a MAC?
thanks in advance,
Maoz
