BabyDoragon
Setting Default Selected Item in a Combo Box
When using a combo box, how can I set it to display the currently selected item by default? For example, if the default is the first item, which is "1", what should I do to have the combo box show "7" as the currently selected item by default, as shown in the image below?
a = {"1", "2", "3", "4", "5", "6", "7", "8", "9", "0"};
New Window( "Test",
	testCB = Combo Box( a, )
Re: Setting Default Selected Item in a Combo Box
Hi @BabyDoragon ,
You can use the 'set' function to place it into the position on the list (this has to be the numbered order for the combo box list)
New Window( "Test",
testcb<<set (1); //set to first position
Extending a little on bens solution
options = {"1", "2", "3", "4", "5", "6", "7", "8", "9", "0"};
initial_option = "7";
nw = New Window( "Test",
	combob = Combo Box(options, << Set(Contains(options, initial_option)))
Scripting Index is usually good place to start
