robot
Set Value as Global Variable
I want to update a NumberColEditBox in a report using global variables.  I have tried various combinations of Eval and Parse, but without success.  I am using JMP9.
// This command works:
reportX[ NumberColEditBox( 1 ) ] << Set Values( [ 1, 2, 3, 4 ] );
// These commands do not work, and generate an "Invalid matrix token" error:
a = 1;
b = 2;
c = 3;
d = 4;
reportX[ NumberColEditBox( 1 ) ] << Set Values( [ a, b, c, d ] );
reportX[ NumberColEditBox( 1 ) ] << Set Values( Eval( [ a, b, c, d ] ) );
reportX[ NumberColEditBox( 1 ) ] << Set Values( [ Eval( a) , Eval( b ), Eval( c ), Eval( d ) ] );
reportX[ NumberColEditBox( 1 ) ] << Set Values( Eval( Parse( [ a, b, c, d ] ) ) );
I suspect my problem is with difficulty putting Global Variables into a matrix.
Any help is appreciated!  Thanks.
ms
Super User (Alumni) ms
Re: Set Value as Global Variable
You can evaluate and convert a list into matrix using Matrix(List).
// JMP 9
nw=new window("test", ncb=numbercoleditbox("ncb",[1,1,1,1]));
L={a,b,c,d}={1,2,3,4};
M=matrix(evallist(L));
ncb<<setvalues(M);
// JMP 10
// It's easier in JMP 10 where <<set  accepts a list directly.
// Nr of rows also changes automatically in JMP10
nw=new window("test", ncb=numbercoleditbox("ncb",[1]));
ncb<<set(L);
ms
// JMP 9
ncb<<setvalues(M);
// JMP 10
ncb<<set(L);
robot
Works great.  Thanks!
