robot
Pause Script Execution with Modal Button Box
I need help inserting a user-controlled pause in script execution.  I am using JMP9.
I have a loop that runs though several files and runs the Nonlinear Fit platform on each.  I would like to add a button box on the Nonlinear Fit platform that will pause the script execution so that the user can confirm the fit parameters are correct before moving on to the next analysis.  What is the best way to implement this?  Some of my attempts are below.
Thanks in advance for the help!
// This works, but does not pause the script execution.
nonlinearfit << Append(
  Button Box( "Click here when fit is finalized.",
  (nonlinearfit[Outline Box( 2 )] << Close( 1 ) ; nonlinearfit<< Journal ; parameters = nonlinearfit[Number Col Edit Box( 5 )] <<
  Make Into Data Table ; )
// These do not work.
  Button Box( "Click here when fit is finalized.", << Modal,
  Make Into Data Table ; ) << Modal
  ) << Modal
ms
Super User (Alumni) ms
Re: Pause Script Execution with Modal Button Box
I am not sure how the button is to be used. The problem with a modal window is that nothing happens (scriptwise or interactively) until OK is clicket. It may also be difficult to press the button in a particular nonlinear window as new windows are created and crowding the screen.
Below is one solution that let's the user click "Go" to complete the nonlinear fit, review results and when done click a button that both saves results (to journal and table) and moves on to the next table. Will this approach work in your setting?
bigClass = Open( "$SAMPLE_DATA/Big Class.JMP" );
bigClass << New Column( "height estimate",
     Numeric,
     Continuous,
     Format( "Best", 12 ),
     Formula( Parameter( {a = 1, b = 1, c = 1, d = 1}, a * (:weight + b) + c * :weight * Sine( d * :weight ) ) )
datatables = {bigClass, bigClass, BigClass}; //List of datatables to loop over
nfiles = N Items( datatables ); // number of tables
tablenr = 1;
parameters = New Table( "Parameters", New Column( "Dataset", character ) ); // A table for saving parameters from all fits
nonlin = Expr(
     nonlinearfit = New Window( "Nonlinear Fit",
          hlb = H List Box(
               Eval( datatables[tablenr] ) << Nonlinear( Y( :height ), X( :height estimate ), Newton ),
               V List Box(
                     Text Box( "Click below when fit is finalized" ),
                     Button Box( "Save results and run next table",
                          nonlinearfit[Outline Box( 2 )] << Close( 1 );
                          nonlinearfit[Outline Box( 1 )] << Journal;
                          parameters_temp = nonlinearfit[Number Col Edit Box( 3 )] << Make Into Data Table;
                          namecol = parameters_temp << New Column( "Dataset", Character, set each value( Eval( datatables[tablenr] ) << get name ) );
                          namecol << move to( first );
                          parameters << Concatenate( parameters_temp, Append to first table );
                          nonlinearfit << close window;
                          Close( parameters_temp, no save );
                          If( tablenr < nfiles,
                               tablenr++;
                               nonlin;  // Next table
                               nonlinearfit << Bring Window To Front;
nonlin;
robot
Here is an example script to help make debugging easier.
  Numeric,
  Continuous,
nonlinearfit = New Window( "Nonlinear Fit", bigClass << Nonlinear( Y( :height ), X( :height estimate ), Newton ) );
  (nonlinearfit[Outline Box( 2 )] << Close( 1 ) ; nonlinearfit << Journal ; parameters = nonlinearfit[Number Col Edit Box( 3 )] <<
New Window( "Text Box", <<Modal, Text Box( "Wait!  Don't run this text box yet!" ), Button Box( "OK" ) );
ms
     Numeric,
     Continuous,
tablenr = 1;
nonlin = Expr(
          hlb = H List Box(
               V List Box(
                               tablenr++;
nonlin;
robot
Brilliant!  Thank you very much MS!
