robot
Set Row Values as Character Sequence
What is the best way to set row values for a given column as a character sequence?
This is easily done when creating a new column (Data Type == Character) by: Column Info --> Initialize Data --> Sequence Data --> "a", "b", "c", etc.
What is the best way to script this?
I am using JMP10.
Thanks!
ms
Super User (Alumni) ms
Re: Set Row Values as Character Sequence
Clever workaround!
Here's another way I've used that may be more general and not requiring a formula (but there "should" be a simpler way..):
dt = Open( "$SAMPLE_DATA/Big Class.JMP" );
labels = {"a", "b", "c"}; // could be any sequence
dt << New Column( "Char Sequence2",
       Character,
       Nominal,
       Values(
              Insert(
                      Repeat( labels, N Rows( dt ) / N Items( labels ) ),
                      If( Mod( N Rows( dt ), N Items( labels ) ),
                             labels[1 :: Mod( N Rows( dt ), N Items( labels ) )],
robot
I found one simple workaround.  Set values using Sequence and then change these values to the desired character string using Value Labels.
bigClass = Open( "$SAMPLE_DATA/Big Class.JMP" );
bigClass << New Column( "Char Sequence",
  Character,
  Nominal,
  Format( "Best", 9 ),
  Formula( Sequence( 1, 3, 1, 1 ) ),
  Value Labels( {1 = "a", 2 = "b", 3 = "c"} ),
  Use Value Labels( 1 )
ms
Clever workaround!
       Character,
       Nominal,
       Values(
              Insert(
robot
Thanks MS.
Yes, it seems there is no simple answer for this one.
Nate_Riordan
Staff (Retired)
Facing this problem myself today I found this post.  It did give me a few logic ideas.  Below is a slightly more condensed technique.
       Character,
       Nominal,
       Set Each Value(labels[1 + Mod( Row() - 1, n items(labels) )])
Indeed I had hoped for sequence to function on character as well.  But at least leveraging set each value you can simplify the flow.
