gallardet
Set Current Directory
Hi.
I have written some sentences to set the current directory where to find the files of interest but it dones not work. Any help? Thanks
Set Current Directory( "/Users/manel/Desktop/Municipales_Spain" );
my_file = Pick File( {"All files|*"} );
dt = Open( my_file );
dt << Select Where(
	Código de Provincia == 44
SubDt = dt << Subset( output table name( "Matarranya1" ) );
Close( "Matarranya1", Save( "/Users/manel/Desktop/Municipales Spain/04_1995Terol.jmp" ) );
Close All( Data Tables, No Save );
cwillden
Re: Set Current Directory
Would this do what you need?
path = "/Users/manel/Desktop/Municipales_Spain";
my_file = Pick File( "", path, {"All files|*"} );
dt << Select Where(
Close( "Matarranya1", Save( path||"/04_1995Terol.jmp" ) );
-- Cameron Willden
vince_faller
The scripting index (Help>>Scripting Index) doesn't say there's anything called set current directory().  Are you looking for
Set File Search Path(
	{Convert File Path( "$SAMPLE_DATA/" ), Convert File Path( "$SAMPLE_DATA/Time Series/" )}
Vince Faller - Predictum
gallardet
Hi Vince, I try your proposal but I can't change the directory.
Set File Search Path( {Convert File Path( "/Users/manel/Desktop/ELECCIONS/JMP coses/Scipts/" ), Convert File Path( "/Users/manel/Desktop/Municipales_Spain/" )} );
When I ask about the  Default Directory();
I get:
cwillden
dt << Select Where(
-- Cameron Willden
gallardet
Eureka!
Thanks a lot!
Just to add to the other responses, you should not use the Set Current Directory() function. It has been deprecated because of bad behavior. The correct function to use is Set Default Directory().
Set Default Directory( "$SAMPLE_DATA" );
Open( "Big Class.jmp" );
