JohnAvina
Send Expects Scriptable Object in access or evaluation of 'Send' , obj << /*###*/Journal << /*###*/Close Window/*###*/
Here is some code that throws this error.  Why is it happening?  I don't have a clue.
//Fan Statuses vs. Occupancy graphs
For( j = 1, j <= N Items( var ), j++, //Outer loop to cycle within list of variables
	v1 = Char( "Time " || var[j] || "_FanStatus" );
	v2 = Char( var[j] || "_FanStatus" );
	obj = Graph Builder(
		Size( 1400, 800 ),
		Variables(
			X( Column( v1 ) ),
			X( :Time Final, Position( 1 ) ),
			Y( Column( v2 ) ),
			Color( :Occupancy )
		Elements(
			Line( X( 1 ), Y, Color( 0 ), Legend( 2 ), Connection( "Step" ) ),
			Heatmap( X( 2 ), Legend( 3 ) )
			Dispatch( {"Line"}, "", OutlineBox, {Close( 0 )} ),
			Dispatch( {"Heatmap"}, "", OutlineBox, {Close( 0 )} ),
			Dispatch(
				v1,
				ScaleBox,
				{Min( :Time Final[1] ), Max( :Time Final[N Rows( :Time Final )] ), Interval( "Minute" ),
				Inc( 15 ), Minor Ticks( 0 ), Label Row( Label Orientation( "Angled" ) )}
			Dispatch(
				"400",
				ScaleBox,
				{Legend Model(
					3,
					Properties( 0, {Transparency( 0.5 )}, Item ID( "Occupied", 1 ) ),
					Properties( 1, {Fill Color( 4 ), Transparency( 0.5 )}, Item ID( "OptStart", 1 ) ),
					Properties( 2, {Fill Color( 2 ), Transparency( 0 )}, Item ID( "Unoccupied", 1 ) )
			Dispatch( {}, "graph title", TextEditBox, {Set Text( "Raney " || v2 || " vs. Occ" )} )
	obj << Journal << Close Window;
Thierry_S
Re: Send Expects Scriptable Object in access or evaluation of 'Send' , obj << /*###*/Journal << /*###*/Close Window/*###*/
The object "GraphBuilder" cannot be sent to a Journal. You need to retrieve the Report: report (obj) << Journal;
Also, it is unclear whether you are trying to close the Journal or close the Obj with the last statement of your script. I recommend separating these two steps.
Best,
TS
Thierry R. Sornasse
I do not see this issue with this simple example of the steps in your process:
Names Default to Here( 1 );
obj = dt << Graph Builder(
	Size( 534, 456 ),
	Show Control Panel( 0 ),
	Show Legend( 0 ),
	Variables( X( :height ), Y( :weight ) ),
	Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) )
obj << Journal;
obj << Close Window;
