キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
DLC7JMP
Send Expects Scriptable Object in access or evaluation of 'Send' ,
Good Afternoon,
    I get this or similar error when trying to "write". "Record" or "save" data output
Send Expects Scriptable Object in access or evaluation of 'Send' , G << /*###*/
'Send' , G << /*###*/Save( "/homedirectory/Drug_test.txt" ) /*###*/
As an example I used Fitmodel example (below) for "Drug.jmp", which is a JMP example file.
dt = Open( "$SAMPLE_DATA/Drug.jmp" ); obj = dt << Fit Model( Y( :y ), Effects( :Drug, :x ), Personality( Standard Least Squares ), Emphasis( Minimal Report ), Run ); G = obj << Get Effect PValues; Show( G ); //values show in log G << Save( "/homedirectory/Drug_test.txt");// I get the error message:Send Expects Scriptable Object in access or evaluation of 'Send' , G << /*###*/
// 'Send' , G << /*###*/Save( "/homedirectory/Drug_test.txt" ) /*###*/ // also did not work G<<savetext("/homedirectory/G.txt")
What am I doing wrong?
DLC7JMP
1 件の受理された解決策
受理された解決策
Re: Send Expects Scriptable Object in access or evaluation of 'Send' ,
What are you trying to save in this case? If you wish to save the results into a text file, you have to use Save Text File
dt = Open("$SAMPLE_DATA/Drug.jmp");
	Y(:y),
	Effects(:Drug, :x),
	Personality(Standard Least Squares),
	Emphasis(Minimal Report),
	Run
Save Text File("$TEMP/drugtest.txt", Char(G));
Web("$TEMP/drugtest.txt"); // should open in default .txt application
So in this case you are using sending incorrect message to a matrix.
元の投稿で解決策を見る
6件の返信6
	Y(:y),
	Effects(:Drug, :x),
	Run
DLC7JMP
Thank you.  This works fine.
Would you care to address why this test loop only open "analysis" windows with out "Y" variables?
This is a test for only 3 columns of data.  My goal is to run this on 4,500 columns and store the two p-values for each analyses.
// Open file
dt = Open("home/AND_Counts_alphaorder_SumNorm.jmp");
// Define the range of response columns
startColumn = 31;
endColumn = 33;
// Loop over the response columns
For(col = startColumn, col <= endColumn, col++,
	responseVar = Column(dt, col) << Get Name;
		Y(responseVar),
		Effects(:mass, ::Accl_Temp_ordinal),
		Run
P = obj << Get Effect PValues;
Save Text File("~/Projects_AB/Ptest.csv", Char(P));
// This open 3 windows w/out "Y"
I think it might be enough if you just add Eval() around your responseVar (and fix Accl_Temp_ordinal scope from :: to :). Also if you are working with that many columns, test it with much smaller amount first so you can make the script work in such a way, that you don't end up with 4500 Fit Model platforms open by accident. Below should be version of your script with the fixes I suggested
startColumn = 31;
endColumn = 33;
		Y(Eval(responseVar)),
		Effects(:mass, :Accl_Temp_ordinal),
		Run
This is a bit different type of method but maybe it can give some ideas at least on how to collect the results and how you can close the reports
colnames = {"height", "weight"}; // many method of getting these
colpvals = Associative Array();
For Each({colname}, colnames,
	colname = "height"
	fm = dt << Fit Model(
		Y(Eval(colname)),
		Effects(:age, :sex),
		Run
	pvals = fm << Get Effect PValues;
	// list conversion seems to be necessary for for JSON conversion
	// and it is easiest to do here
	colpvals[colname] = As List(pvals);
	fm << close window;
	wait(0); // most likely unnecessary
Save Text File("$TEMP/test.json", As JSON Expr(colpvals));
// Web("$TEMP/test.json");
You might also want to consider collecting the results into JMP data table and converting that to .csv but that depends on the final result you wish to have.
DLC7JMP
Jarmo,
  Thanks, I try this and "Accept as Solution" if it works.
Thanks again.
Doug
DLC7JMP
Hi Jarmo,
Your solution worked.
Thank you!!
However, the "Save Tex File " as a text or csv, overwrote each entry leaving only the last p-value.
Thus I combined your two files to create a JSON file, with notes at the bottom of the script to describe how to import into JMP.
See below for t
Thanks again.
Doug
dt = Open("~home/mydatafile.jmp");
startColumn = 23;
endColumn = 42;
		Run
Pv = fm << Get Effect PValues;
	colpvals[responseVar] = As List(Pv);
	fm << close window;
Save Text File("~home/Ptest4.json", As JSON Expr(colpvals));
// NOTE: open JSON file in JMP as "Data (Using Preview)" not best guess.
// top left choose "Stack" (upper right) and "Huge Guess" (under "Guess" pull down)
// File is columns of "responseVar" (data column names), rows are the two p-values
// Transposing in JMP may be desirable.
You will have to collect the results into a list / matrix / some other data structure inside the loop and then handle saving that OUTSIDE the loop.
You could also first create the file as empty (or in the first cycle of the loop) with replace mode (default mode) and then append new data to the file using replace mode Save Text File(path, text|BLOB, <Mode("Replace"|"Append")>) .
Most likely you would want to add headers to the .csv file and the column name.
filepath = "$TEMP/test.csv";
		Y(Eval(colname)),
		Run
	fm << close window;
	If(!File Exists(filepath),
		savemode = "replace";
		savemode = "append"
	Save Text File(filepath, Char(pvals) || "\!N", mode(savemode));
// Web(filepath);
If I were to do something like this, I would most likely collect the results into JMP table, clean it if needed and save into desired format
dt_result = Empty();
		Y(Eval(colname)),
		Run
	dt_p = Report(fm)[Outline Box("Effect Tests"), Table Box(1)] << Make Combined Data Table(Invisible);
	fm << close window;
	dt_p << Delete Scripts(dt_p << Get Table Script Names);
	If(Is Empty(dt_result),
		dt_result = dt_p;
		dt_result << Set Name("pvalues");
		dt_result << Concatenate(Append to first table, dt_p);
		Close(dt_p, no save);
dt_result << show window(1);
You could then save this into a .csv using (or save it as JMP table to make sure you don't lose any data in decimals)
dt_result << Save("$TEMP/test.csv");
おすすめの記事
