KST-CPT
Send Expects Scriptable Object in access or evaluation of 'Send'
I created a modal dialog box to gather some information before running through the rest of the script.  It works but I get the following error in the log file and I don't understand why I get the error?
Send Expects Scriptable Object in access or evaluation of 'Send' , nw1 << /*###*/close window/*###*/
Here is the code for the modal window:
nw1 = New Window( "Setup Window", <<modal,
H List Box(
Panel Box( "Which Machine in East (M9/M11)?", H List Box( rb1 = Radio Box( {"M9", "M11"} ) ), ),
Panel Box( "Fetch New Data (Yes/No)?", H List Box( rb2 = Radio Box( {"Don't Update Data", "Update Data"} ) ), ),
Panel Box( "Actions",
H List Box(
okb1 = Button Box( "OK",
M9M11 = rb1 << get selected;
DataYN = rb2 << get selected;
If( M9M11 == "M9",
Machine = "M9";
ErrorLogScript = "M9-Error_Log.jsl";
RunTimeScript = "M9-RunTime.jsl";
ScriptPath =
"\\goldlnk.rootlnka.net\glddfs002\SHARED\SHARED\OPS\Micro-Electronics Mfg\Microwave\MRSI EAST 705 M8-M11 ERROR LOGS\M9-Combined\";
ELDTfolder =
"\\goldlnk.rootlnka.net\glddfs002\SHARED\SHARED\OPS\Micro-Electronics Mfg\Microwave\MRSI EAST 705 M8-M11 ERROR LOGS\M9 Data Tables\";
ELDTfile = "MRSI M9 Sorted Error Log.jmp";
RTDTfolder =
RTDTfile = "M9 MRSI 705 East Run Time Log.jmp";
Machine = "M11";
ErrorLogScript = "M11-Error_Log.jsl";
RunTimeScript = "M11-RunTime.jsl";
ScriptPath =
"\\goldlnk.rootlnka.net\glddfs002\SHARED\SHARED\OPS\Micro-Electronics Mfg\Microwave\MRSI EAST 705 M8-M11 ERROR LOGS\M11-Combined\";
ELDTfolder =
"\\goldlnk.rootlnka.net\glddfs002\SHARED\SHARED\OPS\Micro-Electronics Mfg\Microwave\MRSI EAST 705 M8-M11 ERROR LOGS\M11 Data Tables\";
ELDTfile = "MRSI M11 Sorted Error Log.jmp";
RTDTfolder =
RTDTfile = "M11 MRSI 705 East Run Time Log.jmp";
Wait( 1 );
If( DataYN == "Don't Update Data",
//Do nothing
Include( ScriptPath || ErrorLogScript );
Include( ScriptPath || RunTimeScript );
Wait( 1 );
nw1 << close window;
canb1 = Button Box( "Cancel",
//in the future would like a way to terminate without continuing
Byron_JMP
Re: Send Expects Scriptable Object in access or evaluation of 'Send'
Take out the close window part.
By sending the modal message you automatically get the "ok" button that closes the window.
so then when you try to close it with "close window" its already closed.
and the close goes to the result of the button, hence the error message, you can't send close (or really anything) to the result of the button close.
Byron_JMP
