Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
AlterEgo
Self-reference in the hot-spot script ("Set Menu Script"). Is it possible?
is self-reference possible in the hot-spot commands ("<< Set Menu Script"), similar to "<<Set Function".
E.g., in the example below I'd like to have a hot-spot commands instead of the buttons:
names = {"AAAA", "BBBB", "CCCC", "DDDD"};
New Window( "Example",
	For( i = 1, i <= N Items( names ), i++,
		<<append(
			Outline Box( names[i], Button Box( "Show my name", <<Set Function( Function( {self}, Show( (self << parent) << get title ) ) ) ), )
 What I'd like to have is something like below:
		<<append(
				<<Set Menu Script(
					{ "Show my name", <function with reference to self here> },
Assigning each outline box to variable is not an option. I need to be able to do it dynamically. Any ideas?
Thanks
Re: Self-reference in the hot-spot script ("Set Menu Script"). Is it possible?
Not sure if there is anything like << set function for outline boxes and their context menu, but you can use Eval(EvalExpr()) (or other methods, Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute ) for quite similar effect
vlb = V List Box();
For Each({name}, names,
	vlb << append(ob = Outline Box(name));
	Eval(EvalExpr(ob << Set Menu Script(
		{"Show my name", Show(Expr(ob) << get title)}
nw = New Window( "Example", vlb);
(nw << XPath("//OutlineBox")) << Get Menu Script;
AlterEgo
Thanks! Excellent, just what I need.
vlb = V List Box();
AlterEgo
