Selecting cells with empty data
I have a table that looks like the table below:
operator M type description description 2 M1 M2 M3 M4 M5 M6
415 Nxyz A hot Hot clean 1 415 415 415 415 415 415
615 Nxyz B cold Cold clean 1 615 615 615   615 615
815 Nxyz A hot Hot clean 2 815 815 815 815 815 815
1015 Nxyz B cold Cold clean 2 1015   1015 1015 1015 1015
1215 Nxyz A hot Hot clean 1 1215 1215 1215 1215 1215 1215
1415 Nxyz B cold Cold clean 1 1415 1415 1415 1415 1415
1615 Nxyz A hot Hot clean 2 1615 1615 1615 1615 1615 1615
1815 Nxyz B cold Cold clean 2 1815 1815 1815     1815
I want to select only the rows that is empty. Since the columns M1-M6 can vary each time I pull the data I can't use the column names in the JSL script. I'm trying to use a FOR loop below to select the rows of empty data, but this only selects the rows where the last cell is empty.
nc = dt << get column names( Numeric );
For( i = 1, i <= N Items( nc ), i++,
dt <<select where( Is Missing( nc[] )));
Eventually I want to get the output table to look like the following
operator M type description description 2 Machine
615 Nxyz B cold Cold clean 1 M4
1015 Nxyz B cold Cold clean 2 M2
1415 Nxyz B cold Cold clean 1 M6
1815 Nxyz B cold Cold clean 2 M4
1815 Nxyz B cold Cold clean 2 M5
The big trick to this is to do this without coding in the column names for (M1,M2 etc...) as they are going to change.
Any Ideas
Jeff_Perkinson
Re: Selecting cells with empty data
If I'm reading your message correctly, I think you've actually got two questions.
  1. How to find the rows that are all missing for a given set of columns.
  2. How to make your code not dependent on the names of those columns and how many there are.
Not surprisingly there are lots of different ways to do 1. PMroz , MS and Craige@JMP have given you some options there.
I'll throw in one more. You could use the Missing Data Pattern utility to find them.
dt = Open( "$SAMPLE_DATA\Cities.jmp" );
//delete some columns from this table to make it fit your example
dt << delete columns( "PM10", "X", "Y" );
//change name of data table to ensure this modified version doesn't get saved
//over the sample data
dt << set name( "CitiesModified" );
//I want to use the columns starting at column 9,
//so I build a list of references to them
mycols = {};
For( i = 9, i <= N Cols( dt ), i++,
	Insert Into( mycols, Column( dt, i ) )
mdp = Dt << Missing Data Pattern( columns( Eval( mycols ) ), Output Table( "Missing Data Pattern" ) );
//The patterns columns shows the pattern of missing values
//the Missing Data Pattern data table is sorted,
//so if there are rows with all missing data
//the last row of the Missing Data Pattern data table will be all 1s.
//The Repeat() function just builds a string of 1s for as many columns as I'm working with
If( Column( mdp, "Patterns" )[N Rows( mdp )] == Repeat( "1", N Items( mycols ) ),
//The Missing Data Pattern data table is linked to the source table so selecting a row
	//in it, selects all the rows that it represents in the source table
	mdp << Select Rows( N Rows( mdp ) );
//now I can delete the rows in the source table
	dt << delete rows;
	Show( "No all missing rows" )
I've tried to show how to make this code work for any number of columns. In this case, because I needed a list of columns to pass to the Missing Data Pattern utility, I built a list based on the column numbers.
Even having written all of this and having shown how to use the Missing Data Pattern Utility, I think my favorite solution here would be PMroz's to use Stack Columns. You really want to end up with the data stacked anyway, so doing that first makes it easy to simply select the missing rows in the stacked column and delete them.
//again I need a list of columns to use in the Stack()
mycols = {};
//stack those columns creating a new data table
stacked_dt = dt << Stack(
	Source Label Column( "Gas" ),
	Stacked Data Column( "PPM" )
missing_rows = stacked_dt << get rows where( Is Missing( :PPM ) );
stacked_dt << delete rows( missing_rows );
-Jeff
pmroz
You can use the STACK command to stack your data, including the values of M1-Mn .  Then select rows that are empty and delete them.
Or try this code:
col_list = dt << get column names( Numeric, string );
where_clause = "";
     one_col = col_list[i];
     if (i == 1,
     // then
           where_clause =evalinsert("\[dt << select where(is missing(as column(dt, "^one_col^"))]\");
     // else
           where_clause = evalinsert("\[^where_clause^ | is missing(as column(dt, "^one_col^"))]\");
where_clause = where_clause || ")";
eval(parse(where_clause));
Same answer as PMroz using expression manipulation:
e = Expr( Or() ); // the OR of the ismissing(columns) will be built here
    Insert Into( e, Eval Expr( Is Missing( Expr( nc ) ) ) )
dt << selectwhere( e );
the expression "e" looks like
nameexpr(e)
Is Missing( :m1 ) | Is Missing( :m2 ) | Is Missing( :m3 ) | Is Missing( :m4 ) | Is Missing( :m5 ) | Is Missing( :m6 )
Head Arg Recurse Formula
Introspection
pmroz
Very slick.  Didn't know you could insert into an expression (e).  I thought insert into needed a list.
ms
Super User (Alumni) ms
Yet another way to select rows with empty cells:
dt << select where(!Contains(Loc Nonmissing(dt << get as matrix), Row()));
pmroz
MS that's even slicker - now let's see you do it in 0 lines of code!  Ha ha just goes to show there are several ways to do the same thing in JSL.
Jeff_Perkinson
mycols = {};
	dt << delete rows;
mycols = {};
-Jeff
Thanks everyone.....Everything worked except the Loc Nonmissing.....I only have JMP9 at the moment (too lazy to upgrade) and that feature doesn't work in JMP9......I'm still a JSL newbie.....Thanks again
