markschahl
Select rows #x to #y in a table
A colleague that is a new JMP user came to me with the following question:
"How to select a given range of rows in a data table?"
Example: I want to select rows 10000-35000.
We searched through the help, manuals, and I searched jmp.com and this forum. Could not find the answer. With a large data table, you can't easily select the first row and then scroll to the last desired row.
Afterthought to the developers: if this can't be done, how about adding row number to the Data Filter dialog or Select By Row Number to Row Selection?
peterw
Re: Select rows #x to #y in a table
You can add another column, and add a formula with the function "row()" - then you can use the Data Filter in the Rows menu item to select the rows you want. See screenshot below
peterw
pmroz
You can also use a JSL script to do this:
dt = open("$sample_data\Big Class.jmp");
select_matrix =index(20,35);
dt << select rows(select_matrix);
Change dt to point to your table, and change the rows mentioned in the call to index to the rows you desire.  E.g. for your situation you would say:
dt = open("your table here");
select_matrix =index(10000,35000);
mtl
mtl
One possible method, at least in the BASE SAS world, would be like below.  Don't know if it directly applies to your case in JMP:
242  data a;
243      do i=1 to 10;
244          row=i;
245          output;
246      end;
247  run;
NOTE: The data set WORK.A has 10 observations and 2 variables.
NOTE: DATA statement used (Total process time):
      real time           0.00 seconds
      cpu time            0.00 seconds
248
249  proc sql noprint;
250      create table b as
251      select *, monotonic() as rownum
252      from a
253      where monotonic()<=7 and monotonic()>=4;
NOTE: Table WORK.B created, with 4 rows and 3 columns.
254  quit;
NOTE: PROCEDURE SQL used (Total process time):
255
256  data _null_;
257      set b;
258      put row=;
259  run;
row=4
row=5
row=6
row=7
NOTE: There were 4 observations read from the data set WORK.B.
paramaribo
At least in Base SAS you can do this below.  Just not sure in JPM.
Here is an example code:
Data subset_of_cars;
     row_no +1; /* Just for demo/checking purpose*/
     set sashelp.cars;
     if _n_ >= 100 and _n_ <= 200;
run;
