aserino
Select rows based of multiple conditions
I'm trying to select rows where either the second or third column have a value below 10^-9, or if there is a missing value in the 4th column. The problem appears to be with the less than operator and I cannot figure out why.
Example table:
Col1
Col2Col3Col4
10.000000590.000000308
A
24.08e-9-8.1e-11B
3-1.11e-101.02e-10
Here's the code:
dtColNames = dt << get ColumnNames("String");
val = 10^-9;
dt << Select Where((dt:dtColNames[2]<val | dt:dtColNames[3]<val ) | ismissing(dt:dtColNames[4]));
If I simplify this down to the following:
val = 10^-9;
dt << Select Where(dt:dtColNames[2]<val );
nothing is selected, when row 3 should be.
Re: Select rows based of multiple conditions
A character string is not a column name or reference. You need to convert the string to a column reference.
dt << Select Where( Column( dt, dtColNames[2] )[] < val | Column( dt, dtColNames[3] )[] < val | ismissing( Column( dt, dtColNames[4] )[] ));
aserino
Ah! Thanks!
