CanhKhong
Select matching cells
How can I have "select matching cells" for two different cells (from the same row)?
I can do seclec matching cells for one cells but not able to do for two cells.
Re: Select matching cells
go to the first cell you want to match on and click on it. Then go to the second cell, hold down the CNTL key and click on that cell. Move to the row state column for the row that has the selections in it and right click on the cell,and select "select matching cells"
CanhKhong
Thanks for the trick/help.
After select one cell, I just right click and find the option of "Select Matching Cells", but if I select more than one cell, I have to right click on the status column. This is the difference.
Thanks again
