DamionSparhawk
Select issue
I create a graph, and when I go to select a portion of it, it highlights the entire excel sheet. I remember from demo that you should be able to select a segment and have it only highlight the data directly relating to that segment. What am I doing wrong here?
I would also like to know if there is any way to have JMP find the peak data from multiple points on the same line and display them in the graph?
Thank you for your time
20 REPLIES 20
DamionSparhawk
Re: Select issue
Trying a slightly different tact, I got rid of the part of the script that adjusts the size and appearance of the dots and simply changed those settings in my preferences for now, I realized that the script I had prior to that was not actually putting the points on to the additional graphs (more than the first) so I came up with this one. However it is doing some rather bizarre thing where it plots out a second graph of the first line completely on it's own in smooth...
dt = Open ();
col_list = dt << get column names(string);
remove from(col_list, 1);	// Remove time[sec] from list
cols_to_plot = {};
offset_list  = {};
offset_cols  = {};
// Define the graph builder commands in an expression for use by the OK button
graph_expr = expr(
	for (i = 1, i <= nitems(cols_to_plot), i++,
		new_name = cols_to_plot[i] || "-Chemical Cal";
		insertinto(offset_cols, new_name);
		dt << new column(new_name, Numeric, "Continuous", Format( "Best", 12 ),
			Formula( as column(dt, cols_to_plot[i]) * offset_list[i] ) );
// Now for the graph - build a text string and then execute it
	gb_text = "\[gb = graph builder(
	show control panel(0),
	variables(
		X( :Name( "Time[sec]" ) ),]\";
	elements_txt = "	),
	Elements( Line( X, ";
	For( i = 1, i <= N Items( cols_to_plot ), i++,
		If( i == 1,
		// then
			gb_text = gb_text || Eval Insert( "\!N\[		Y( :Name( "^offset_cols[i]^" ) ), ]\" )
		// else
			gb_text = gb_text || Eval Insert( "\!N\[		Y( :Name( "^offset_cols[i]^" ), Position( 1 ) ),]\" )
		elements_txt = elements_txt || Eval Insert( "Y ( ^i^ ), " );
	"Legend( 7 ) ),
	Points( X, ";
		If( i == 1,
		// then
		// else
	"Legend(8))
	gb_text = gb_text || elements_txt || "); ";
	Eval( Parse( gb_text ) );
nw = new window("Graph Chemicals",
	panel box("Select channels to graph",
		lineup box(ncol(2),
			text box("Column"), text box("Chemical Cal"),
			cb1 = checkbox("Ch1"), ch1_neb = number edit box(),
			cb2 = checkbox("Ch2"), ch2_neb = number edit box(),
			cb3 = checkbox("Ch3"), ch3_neb = number edit box(),
			cb4 = checkbox("Ch4"), ch4_neb = number edit box(),
			cb5 = checkbox("Ch5"), ch5_neb = number edit box(),
			cb6 = checkbox("Ch6"), ch6_neb = number edit box(),
			cb7 = checkbox("Ch7"), ch7_neb = number edit box(),
			cb8 = checkbox("Ch8"), ch8_neb = number edit box(),
			cb9 = checkbox("Ch9"), ch9_neb = number edit box(),
	panelbox("Actions",
		hlistbox(
			okb  = button box("OK",
				if (cb1 << get(1),
					insertinto(cols_to_plot, col_list[8]);
					offset_value = ch1_neb << get;
					insertinto(offset_list, offset_value);
				if (cb2 << get(1),
					insertinto(cols_to_plot, col_list[9]);
					offset_value = ch2_neb << get;
				if (cb3 << get(1),
					insertinto(cols_to_plot, col_list[10]);
					offset_value = ch3_neb << get;
				if (cb4 << get(1),
					insertinto(cols_to_plot, col_list[11]);
					offset_value = ch4_neb << get;
				if (cb5 << get(1),
					insertinto(cols_to_plot, col_list[12]);
					offset_value = ch5_neb << get;
				if (cb6 << get(1),
					insertinto(cols_to_plot, col_list[13]);
					offset_value = ch6_neb << get;
				if (cb7 << get(1),
					insertinto(cols_to_plot, col_list[14]);
					offset_value = ch7_neb << get;
				if (cb8 << get(1),
					insertinto(cols_to_plot, col_list[15]);
					offset_value = ch8_neb << get;
				graph_expr;
				nw << close window;
			canb = button box("Cancel", nw << close window;
// Pre-check checkboxes if column exists
for (i = 1, i <= nitems(col_list), i++,
	if (col_list[i] == "Ch1", cb1 << set(1, 1),
		col_list[i] == "Ch2", cb2 << set(1, 1),
		col_list[i] == "Ch3", cb3 << set(1, 1),
		col_list[i] == "Ch4", cb4 << set(1, 1),
		col_list[i] == "Ch5", cb5 << set(1, 1),
		col_list[i] == "Ch6", cb6 << set(1, 1),
		col_list[i] == "Ch7", cb7 << set(1, 1),
		col_list[i] == "Ch8", cb8 << set(1, 1),
		col_list[i] == "Ch9", cb9 << set(1, 1),
I saved the script for this, and then the script for how I want it to look (just the top graph) but I am not certain what parts I need to edit to get rid of the eroneous graph...
//This is what it graphs
Graph Builder(
	Variables(
		Y( :Name( "CH2-Chemical Cal" ) ),
		Y( :Name( "CH4-Chemical Cal" ), Position( 1 ) ),
	Elements(
		Position( 1, 1 ),
		Line( X, Y( 1 ), Y( 2 ), Legend( 7 ) ),
		Points( X, Y( 1 ), Y( 2 ), Legend( 8 ) )
	Elements(
		Position( 1, 2 ),
		Points( X, Y, Legend( 11 ) ),
		Smoother( X, Y, Legend( 12 ) )
		Dispatch(
			"CH2-Chemical Cal",
			ScaleBox( 2 ),
			{Min( -125.45871559633 ), Max( 1724.54128440367 ), Inc( 100 ),
			Minor Ticks( 1 )}
// This is what I want it to graph
Graph Builder(
	Variables(
	Elements(
