I have this data in graph builder and I was wondering if there was a way with JSL to select all the points that are showing in the current GB arrangement? This would save me from having to hold down control and select all the point in each panel by panel. On some GB arrangements this can be a lot of panels to work through!
You can get the Minimum and Maximum for the Axis Box() for your Y axis, which will return the upper and lower display values. Then you can use Select Where() to select all of the rows in the data table that fall within those values.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '777549' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '777549') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '777549') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
