See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
Select a group of cells in a column
SamH
Hi, I have table with thousands of rows. I need to be able to select a group of cells in one column, so I could copy it into another table. for example for Column: "Test3 (VOLTS)" only I need to copy cells highlighted in yellow from row 4 thru row 18 using JSL code.
Thanks
11 REPLIES 11
Re: Select a group of cells in a column
Here is a simple example  of one way to do it
dt = Open( "$sample_data\big class.jmp" );
// copy the names from row 2-6
NameCpy = dt:name[Index( 2, 6 )];
dt2 = New Table( "copied", New Column( "new name", character ) );
dt2 << add rows( 5 );
// copy to new table
For( i = 1, i <= 5, i++,
	dt2:new name[i] = NameCpy[i]
If you actually have physical rows that are selected, you can easily get their row number with a:
     dt<<get selected rows
SamH
Thanks that should work, I tried with Big class file.
Much appreciated
Sam.
SamH
Hi Jim, how can I select a range of cells withing one column?
for example if I want to select cell 2 thourgh cell 19 within the same column.
Because I want to use this selection to be able to do "Select Matching Cells" within the same column.
Thanks
Sam
Here is the example for "Select Matching Cells" taken from
     Help==>Scripting Index
dt << Select Rows( [1, 2, 3, 4] );
dt << Go To( :Height );
Wait( 2 );
dt << Select Matching Cells();
SamH
Hi Jim, instead of hand picking what cells to select, can I pick a range let's say 2-19?
Thanks
SamH
or row 12 thru 40 in column "height"
SamH
SamH
Jim, I am trying to automate this process, because the files I am dealing with could have 1k-2k rows. if I have to specify every row, my code will be so many pages.
SamH
Jim, I figured it out, here is the code it works.
L = N Rows( dt ); // number of rows
For( i = 3, i <= L, i++,
dt << Select Rows( i, L );
Wait( 2 );
No recommendations found
