Select/Where Statement Pulls from List
Hi!
Not sure if the title describes this issue the best, but I feel like I am on the verge of getting this figured out.
I have one JMP table with a column TestID and I want to select rows from another data table based on the variable TestID list.
dt = Open("Lot List2.jmp");
ID_list = Column( dt, "TestID" ) << Get values;
dt1= Open Database("Connection",
"SELECT
[TestID]
,[Device]
,[FailureMode]
FROM [Database]
where TestID IN 'ID_list'
order by [TestID] Desc","Device Summary");
/* ALSO TRIED*/
dt = Open("Lot List2.jmp"); ID_list = Column( dt, "TestID" ) << Get values; dt1= Open Database("Connection", "SELECT [TestID] ,[Device] ,[FailureMode] FROM [Database] m where m.TestID like 'ID_list' order by [TestID] Desc","Device Summary");
My issue lies somewhere in my 'where' statement, but I am not sure how to call the string of IDs into this statement. The IN statement option does not open a new table, and the like option opens a blank table. My guess is that it treats ID_list as the variable to look for in the other table.
I found a similar question, but the IN statement is not working for me either: https://community.jmp.com/t5/Discussions/how-to-extract-data-with-criteria-of-JMP-table-values/td-p/...
Any insights are appreciated!
Re: Select/Where Statement Pulls from List
ID_list will return you a list of strings (or numbers) and you will have to convert it into a string that SQL query will understand and then add that string to your query. Below is one example of query building using Concat Items and Eval Insert
ID_list = Column(dt, "name") << Get values; // list of strings?
sql_template = "SELECT [TestID], [Device], [FailureMode]
FROM [Database]
where TestID IN ('¤idlist_sql¤')
order by [TestID] Desc";
idlist_sql = Concat Items(ID_list, "','");
sql_str = Eval Insert(sql_template, "¤");
dt1 = Open Database("Connection",
	sql_str
	"Device Summary"
This presentation might give some additional ideas
Oh okay I see the modifications you have to do. I have used this template, but I am still note getting another data table to appear. what is this symbol, ¤ ?
pmroz
The default character for eval insert is "^".  I didn't know you could supply another one.  Looks like Jarmo is using ¤ for that.
To debug:
  • Use print or show to display your SQL statement.
  • Copy/paste it into a program that can execute directly on your database.  For example for Oracle we use PL/SQL Developer, TOAD or SQL Developer
Once you have that working, run it from JMP.
Here's some sample code:
// List of numeric IDs
id_list = {111, 222, 333, 444, 555};
// Convert numbers to text
for (i = 1, i <= nitems(id_list), i++,
	id_list[i] = char(id_list[i]);
in_list = "('" || concat items(id_list, "', '") || "')";
show(in_list);
sql_statement = evalinsert(
"SELECT * from mytable m
  WHERE m.id IN
^in_list^"
show(sql_statement);
Try running this and look for the results in the log window.
