guy_yosef
how to extract data with criteria of JMP table values
Hi
i am trying to extract data for specifc lot list
for now i extract all data and filter the data i need
but
how do i update my data extraction script to take values directly  from JMP table?
example of data table:
New Table( "lot list",
Add Rows( 5 ),
New Column( "lot",
  Character,
  Nominal,
  Set Values( {"AB457", "AB589", "XY671", "XY001", "XY187"} )
example of extract criteria for the lots in the table
"SELECT * FROM \!"LOTTABLE\!"
WHERE \!"LOT\!" in ('AB457','AB589','XY671','XY001','XY187')
pmroz
Re: how to extract data with criteria of JMP table values
You can use CONCAT ITEMS to create an IN list from a JMP list.  For example:
dt = New Table( "lot list",
     Add Rows( 5 ),
     New Column( "lot",
           Character,
           Nominal,
lot_list = Column( dt, "lot" ) << Get values;
in_list = "('" || Concat Items( lot_list, "', '" ) || "')";
sql_string = "SELECT * FROM mytable m WHERE m.lot_number IN " || in_list;
ian_jmp
Level X
If I understand correctly, you want to submit a SQL query from JMP using values held in a table. The code below uses a brute force approach to build the query string, and may give you some ideas. In this example, the values came from a user interface that required the user to select one and only one name, and one or more products.
  reps = repsObj << GetSelected;
  prod = prodObj << GetSelected;
  if (NItems(reps)!=1, Beep(); Dialog("WARNING: You need to select a name"); Throw());
  if (NItems(prod)<1, Beep(); Dialog("WARNING: You need to select at least one product"); Throw());
  // Build the resulting query
  SQLQuery = "SELECT * FROM Final WHERE salesrep_name = '"||reps[1];
  if (NItems(prod)==1,
  // Simple to build the query
  SQLQuery = SQLQuery||"' AND product_group = '"||prod[1]||"';",
  // else takes a bit more work
  prodPart = "' AND (product_group = '"||prod[1];
  for(i=2, i<=NItems(prod), i++, prodPart = prodPart||"' OR product_group = '"||prod[i]);
  prodPart = prodPart||"');";
  SQLQuery = SQLQuery||prodPart;
  // Show(SQLQuery); // Debug
guy_yosef
Thanks for the fast answer
i manged to create array, now i need to find a way to concat it
Add Rows( 5 ),
New Column( "lot",
  Character,
  Nominal,
lots = lot << Get values;
//for example
Show (lots[2]);
lots[2] = "AB589";
pmroz
     Add Rows( 5 ),
     New Column( "lot",
           Character,
           Nominal,
