aandw
Select All Columns and Delete Formula Property?
Comparable to Copy All Paste Special Values in Excel, how can I select all columns in Data Table and delete column formulas while preserving the values of each column in JSL Script?
This previous discussion was a beneficial first step.
JSL - How to remove formula from column?
10 REPLIES 10
Re: Select All Columns and Delete Formula Property?
One non-scripting option would be use Standardize Attributes.  Select all of the columns where you want to remove the formula in Columns box on the left of the data table.  Right click in the blue (highlighted) area and select Standardize Attributes.  Go to Delete Properties at the bottom of the dialog box and select Column Properties.  Select Formula and then click apply.  The formulas should be removed and the values preserved.
