vitali_pom
JSL - How to remove formula from column?
How can I remove a formula from a column without changing it through JSL?
Thanks.
Re: JSL - How to remove formula from column?
Below is another option:
dt = Open( "$SAMPLE_DATA/Bank Loan.jmp" );
:Time << Delete Formula;
Wendy
Jeff_Perkinson
Try the  Delete Property() message to the column.
dt = Open( "$SAMPLE_DATA/Tiretread.jmp" );
:Pred Formula ABRASION << delete property(Formula);
-Jeff
-Jeff
Wendy
lwx228
Level VIII
I just found it at this BBS:
Column(dt, "Values From Formula") << deleteFormula;
Zahti
This is perfect for column names that have special characters in them, thanks!!
Or by using the :Name() function form
:Name("Values From Formula") << deleteFormula;
