Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
It is easy to interactively accomplish your task. Select Analyze > Fit Y by X. Cast the x and y columns into their respective analysis roles and click OK. Click the red triangle and select Fit Polynomial , degree 2
