vishwasanj
Level V
Searching a value in a column- JSL
Hi All,
Can anyone help me with the search for a particular value in a column and try to find the count of that value with the overall count? In the below example, I am trying to search for value "1" in B column. I found 3 occurences in 10 instances so C is marked with 30%. Similarly for A=2, I found 4 occurence of "1" in 12 instances, so C is marked with 33%.
ABC
1130%
187
190
165
11
165
13
11
134
15
2133%
25
22
247
21
254
21
285
21
21
222
221
Thank you
10 REPLIES 10
Re: Searching a value in a column- JSL
You can do virtually anything you want to do in JMP, so yes, there are ways to do what you want.  However, the structure you have is a data table, and it's defaults are based upon a column based analysis table structure, not a cell based structure like Excel.
To do what you are asking, I would do the following.
Go to "Column Info" for the percentage column.
In the Column Info window, remove the formula property.  This will keep the values, but take away the formula.
Then change the "Data Type" from numeric to character
Close the "Column Info" window
Now go and delete the cell values you don't want.
