UserID16644
Search and select word on string
Hi all,
I have two different data tables, and I need to find and select if the word exist on the other table.
I tried using Contains() but is not working. Please help
Here is an example:
dt1
dog
cat
fish
bird
cow
dt2
dog&gorilla
mouse, giraffe
shark, whale, penguin
ostrich&bird
lion&tiger,cow
Result (text in bold characters are selected):
dt2
dog&gorilla
mouse, giraffe
ostrich&bird
lion&tiger,cow
Re: Search and select word on string
Here is one way to do what you are looking for.  Please note, I believe your table that shows the results has row 3 incorrectly selected.
// Create the tables
dt1 = New Table( "Lookup", Add Rows( 5 ), New Column( "key", Character, Set Values( {"dog", "cat", "fish", "bird", "cow"} ) ) );
dt2 = New Table( "Base",
	Add Rows( 5 ),
	New Column( "Target", Character, Set Values( {"dog&gorilla", "mouse, giraffe", "shark, whale, penguin", "ostrich&bird", "lion&tiger,cow"} ) )
// Place all key values into a list
KeyList = dt1:key << get values;
// Loop across the keys and search each row of Target for the
// match
For Each( {val}, keyList,
	For Each Row(
		If( Contains( :Target, val ),
			Row State( Row() ) = Selected State( 1 )
	Add Rows( 5 ),
// match
	For Each Row(
UserID16644
Just a follow up question, can I use this selected rows in matching to other tables? Like in Update?
I am not understand your question.  However, you can easily create a subset of the base table that contains just the selected rows, and then you can update another table from that table.  Here is the JSL to do the subsetting
dt3 = dt2 << Subset( selected columns( 0 ), selected rows( 1 ) );
